Queclink GL300A
Queclink GL300A is an ultralong standby time GPS tracker suitable for logistics and transportation. The device features 2 light sensors and 1 temperature/humidity sensor for environment monitoring, internal GSM/GPS antenna, IP65 water resistant casing, and more.
Parameters (683)
Settings (6)
Queclink GL300A
Flespi parses telemetry data from your Queclink GL300A into a standardized JSON and lets you send commands to Queclink GL300A via API.
    "device.type.id": "Queclink GL300A",
How to send commands to Queclink GL300A?
Fixed Report
fixed_report_gl
mode: Working Mode
corner: Corner Report
end_time: End Time
movement: Movement Detect Mode
start_time: Start Time
check_interval: GPS Check Interval
network_gsm
network_mode: Network Mode
Non-Movement Behavior
non_movement
Non-Movement detection and behavior
movement: Movement
send_interval: Send Interval
