Queclink GB130MG
Queclink GB130MG is a battery-mounted GPS tracker with backup battery, 4G/LTE Cat M1, and BLE 5.2. The device features virtual ignition detection, 1600 Hz 6-axis accelerometer, accelerometer self-calibration, driving behavior monitoring, crash detection, scheduled reports, geofencing, jamming detection, tow alarm, Bluetooth 5.2, IP67 waterproof casing, and more.
Parameters (683)
Settings (22)
Queclink GB130MG
Flespi parses telemetry data from your Queclink GB130MG into a standardized JSON and lets you send commands to Queclink GB130MG via API.
    "device.type.id": "Queclink GB130MG",
How to send commands to Queclink GB130MG?
Cleanup Device Buffer
delbuf
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
Fixed Report
fixed_report_gb
mode: Working Mode
corner: Corner Report
time_range: Time Range
check_interval: Check interval
GNSS-Assisted Motion
gnss_motion_detection
GNSS assisted motion detection settings
speed: Speed Mode
enable: Enable Function
move_time: Motion Cumulative Time
speed_lvl: Motion Speed Threshold
still_time: Motionless Cumulative Time
gnss_fail_time: GNSS Fix Failure Timeout
Global Configuration
gtcfg
Global device configuration parameters
led_on: LED On
agps_mode: AGPS Mode
event_mask: Event Mask
odo_enable: Odometer Enable
device_name: Device Name
odo_mileage: Odometer Initial Mileage
report_mask: Report Composition Mask
power_saving: Power Saving Mode
gnss_lost_time: GNSS Lost Time
cell_info_report: Cell Info Report
info_report_enable: Info Report Enable
low_power_threshold: Low Power Threshold
clear_fplmn_interval: Clear FPLMN Interval
info_report_interval: Info Report Interval
backup_battery_supply: Backup Battery Supply
location_request_mask: Location Request Mask
backup_battery_charge_mode: Backup Battery Charge Mode
Circular Geofence
gtgeo
Circular geofence configuration. Up to 20 zones (ID 0-19)
geo_id: GEO ID
radius: Radius
latitude: Latitude
longitude: Longitude
trigger_mode: Trigger Mode
check_interval: Check Interval
trigger_report: Trigger Report
Driving Behavior Alarm
gthbm
Harsh behavior monitoring settings
ha: High Acceleration Threshold
hb: High Braking Threshold
la: Low Acceleration Threshold
lb: Low Braking Threshold
ma: Medium Acceleration Threshold
mb: Medium Braking Threshold
mode: Working Mode
a_duration: Acceleration Duration
b_duration: Braking Duration
c_duration: Cornering Duration
speed_high: High Speed
a_threshold: Acceleration Threshold
b_threshold: Braking Threshold
c_threshold: Cornering Threshold
speed_medium: Medium Speed
driving_direction: Vehicle Driving Direction
gravity_direction: Vehicle Gravity Direction
Rollover Detection
gtrod
Rollover detection configuration. When enabled, the device reports +RESP:GTROD upon detecting a rollover event.
gravity_direction: Gravity Direction
Speed Alarm
gtspd
Speed alarm settings
max_spd: Max Speed
min_spd: Min Speed
validity: Validity
send_interval: Send Interval
Start/Stop Report
gtssr
Configure start/stop detection parameters
long_stop: Long Stop
time_unit: Time Unit
start_speed: Start Speed
time_to_stop: Time to Stop
time_to_start: Time to Start
location_switch: Location Switch
Stolen Vehicle Recovery
gtsvr_gb130mg
Configure Stolen Vehicle Recovery (SVR) parameters for ghost Bluetooth device detection
ghost_mac: Ghost MAC Address
ghost_imei: Ghost IMEI
ghost_mac_1: Ghost MAC Address 1
ghost_mac_2: Ghost MAC Address 2
ghost_imei_1: Ghost IMEI 1
ghost_imei_2: Ghost IMEI 2
ghost_bt_name: Ghost Bluetooth Name
ghost_bt_name_1: Ghost Bluetooth Name 1
ghost_bt_name_2: Ghost Bluetooth Name 2
report_interval: BTI/SMI Report Interval (minutes)
connect_interval: Connect Interval (minutes)
candidate_pattern: Candidate Pattern
connect_fail_count: Connect Fail Count
extra_ghost_number: Extra Ghost Number
Virtual Ignition Mode
gtvms
Virtual ignition working mode
mode: Working Mode
SMS Whitelist
gtwlt
SMS white number list configuration
phone_1: Phone Number 1
phone_2: Phone Number 2
phone_3: Phone Number 3
phone_4: Phone Number 4
phone_5: Phone Number 5
phone_6: Phone Number 6
phone_7: Phone Number 7
phone_8: Phone Number 8
phone_9: Phone Number 9
phone_10: Phone Number 10
number_filter: Number Filter
Network Setup
network_setup
Configure the parameters for LTE/EGPRS networks (AT+GTBSI command)
lte: LTE Mode
network: Network Mode
apn_auth: APN Authentication Method
manual_netreg: Manual Netreg
Reboot the terminal
Request position
request_position
Reset Parameters
reset_params
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virtual_ignition_accelerometer
Accelerometer virtual ignition validity, used when Virtual Ignition Mode is Accelerometer
rest_timeout: Rest Validity
motion_timeout: Movement Validity
Voltage Virtual Ignition
virtual_ignition_voltage
Voltage virtual ignition detection, used when Virtual Ignition Mode is Voltage
smart: Smart Voltage Adjustment
offset: Voltage Offset
on_voltage: Ignition On Voltage
on_debounce: Ignition On Debounce
off_debounce: Ignition Off Debounce
