Queclink GL300M
Queclink GL300M is a water-resistant asset tracker with LTE support. The device features a 3-axis accelerator, full power management, low power consumption, support for GPS, GLONASS, and Beidou systems, internal 2600 mAh Li-Pol battery, multiple alarms, and more.
Parameters (683)
Settings (6)
Queclink GL300M
Flespi parses telemetry data from your Queclink GL300M into a standardized JSON and lets you send commands to Queclink GL300M via API.
    "device.type.id": "Queclink GL300M",
How to send commands to Queclink GL300M?
Fixed Report
fixed_report_gl
mode: Working Mode
corner: Corner Report
end_time: End Time
movement: Movement Detect Mode
start_time: Start Time
check_interval: GPS Check Interval
Network Setup
network_lte_gprs
Configure the parameters for LTE/GPRS networks
lte: LTE Mode
lte_apn: LTE APN
network: Network Mode
gprs_apn: GPRS APN
lte_password: LTE APN Password
lte_username: LTE APN Username
gprs_password: GPRS APN Password
gprs_username: GPRS APN Username
Non-Movement Behavior
non_movement
Non-Movement detection and behavior
movement: Movement
send_interval: Send Interval
