Queclink GV300L
Queclink GV300L is an advanced vehicle GPS tracker including an RS232 serial port. The device features a 250 mAh backup battery, digital and analog I/O, supports various accessories, such as a CAN adapter as well as temperature and humidity sensors, geofencing alarm, parking alarm, low power alarm, towing alarm, antenna disconnect alarm, alarm when the external GPS antenna is disconnected, driving behavior monitoring, aggressive driving behavior detection, including harsh braking, acceleration, etc., crash detection, and more.
Parameters (682)
Settings (25)
Queclink GV300L
Flespi parses telemetry data from your Queclink GV300L into a standardized JSON and lets you send commands to Queclink GV300L via API.
    "device.type.id": "Queclink GV300L",
How to send commands to Queclink GV300L?
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
Device Parameters
config
agps: AGPS Mode enable
led_mode: LEDs working mode
odometer: Odometer
pwr_mode: Power saving mode
pin15_mode: Pin 15 mode
device_name: Device Name
gps_on_need: GPS On Need
gps_lost_time: GPS lost time
Events
events
ant_event: External GPS antenna status changed
pfa_event: Power off event
pna_event: Power on event
ufs_event: UFSxxx fault code
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
Fixed Report
fixed_report_gv
mode: Working Mode
corner: Corner Report
time_range: Time Range
GSM Reports
gsm_reports
mode: GSM Reports Mode
reports: Select reports
Digital Inputs
inputs
Digital Inputs Control
input1: Input #1
input2: Input #2
input3: Input #3
ignition: Ignition Input
network_gsm
network_mode: Network Mode
Digital Output 1
gtdos: GTDOS Report
Digital Output 2
wave: Wave Shape
Output 3
output3
Digital Output 3
wave: Wave Shape
Reboot the terminal
Report Composition
report
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Request position
request_position
Reset Parameters
reset_params
Data Transmission
send_data_gv300l
Transparent transmission of data to equipment connected to the serial port of the device
ack: Command ACK
crlf: Send data without CRLF
data: Data
uart_port: UART Port
hex_convert: Convert to HEX
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
UART Serial Port
uart_serial_port_gv
Configure the serial port
mode: Working Mode
sleep: Sleep Enable
baudrate: Baudrate
data_bits: Data Bits
stop_bits: Stop Bits
parity_bits: Parity Bits
wakeup_input: Enable Wakeup Input
