Queclink GV300W
The GV300W is a compact GPS tracker designed for a wide variety of vehicle tracking applications. It has multiple I/O interfaces that can be used for monitoring or controlling external devices. Its built-in GPS receiver has superior sensitivity and fast time to first fix. Its triple band WCDMA subsystem supports UMTS/HSDPA 850 (Band V)/1900 (Band II)/2100 (Band I) MHz and quad band GSM/GPRS 850/900/1800/1900 MHz allowing the GV300W's location to be monitored in real time or periodically tracked by a backend server and mobile devices.
Parameters (682)
Settings (27)
Queclink GV300W
Flespi parses telemetry data from your Queclink GV300W into a standardized JSON and lets you send commands to Queclink GV300W via API.
    "device.type.id": "Queclink GV300W",
How to send commands to Queclink GV300W?
Analog Input
analog_input
Analog Input Port Configuration
fuel: Fuel Analog Input
input1: Analog Input #1
input2: Analog Input #2
change_threshold: Change Threshold
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
DR100 Card Reader
cda
DR100 RFID card reader configuration. Configures read mode, card key, memory block, and prefix strings for card validation.
key: Key
read_mode: Read Mode
data_block: Data Block
prefix_number: Prefix Number
prefix_string_1: Prefix String 1
prefix_string_2: Prefix String 2
prefix_string_3: Prefix String 3
prefix_string_4: Prefix String 4
prefix_string_5: Prefix String 5
prefix_string_6: Prefix String 6
prefix_string_7: Prefix String 7
prefix_string_8: Prefix String 8
prefix_string_9: Prefix String 9
prefix_string_10: Prefix String 10
Device Parameters
config
agps: AGPS Mode enable
led_mode: LEDs working mode
odometer: Odometer
pwr_mode: Power saving mode
pin15_mode: Pin 15 mode
device_name: Device Name
gps_on_need: GPS On Need
gps_lost_time: GPS lost time
Events
events
ant_event: External GPS antenna status changed
pfa_event: Power off event
pna_event: Power on event
ufs_event: UFSxxx fault code
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
Fixed Report
fixed_report_gv
mode: Working Mode
corner: Corner Report
time_range: Time Range
GSM Reports
gsm_reports
mode: GSM Reports Mode
reports: Select reports
Digital Inputs
inputs
Digital Inputs Control
input1: Input #1
input2: Input #2
input3: Input #3
ignition: Ignition Input
network_gsm
network_mode: Network Mode
Digital Output 1
gtdos: GTDOS Report
Digital Output 2
wave: Wave Shape
Output 3
output3
Digital Output 3
wave: Wave Shape
Reboot the terminal
Report Composition
report
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Request position
request_position
Reset Parameters
reset_params
Data Transmission
send_data
Transparent transmission of data to equipment connected to the serial port of the device
ack: Command ACK
crlf: Send data without CRLF
data: Data
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
UART Serial Port
uart_serial_port_gv
Configure the serial port
mode: Working Mode
sleep: Sleep Enable
baudrate: Baudrate
data_bits: Data Bits
stop_bits: Stop Bits
parity_bits: Parity Bits
wakeup_input: Enable Wakeup Input
