Queclink GV500MAP
Queclink GV500MAP is an LTE Cat M1/NB1 easy-to-install OBD GPS tracker. It is a compact OBD device that plugs into a vehicle’s OBDII port allowing easy installation for customers. It supports BLE 4.2 that is used for data transmission. Its internal OBD transreceiver can obtain information from the vehicle’s on-board computer. GV500MAP supports LTE Cat M1/NB1 network on multiple bands for operation in North America.
Parameters (683)
Settings (18)
Queclink GV500MAP
Flespi parses telemetry data from your Queclink GV500MAP into a standardized JSON and lets you send commands to Queclink GV500MAP via API.
    "device.type.id": "Queclink GV500MAP",
How to send commands to Queclink GV500MAP?
Device Parameters
config_gv500
agps: AGPS Mode
antenna: GPS Antenna Mode
led_mode: LEDs Working Mode
odometer: Odometer
pwr_mode: Power Saving Mode
sleep_mode: Sleep Mode
device_name: Device Name
no_ign_mode: No Ignition Mode
gps_lost_time: GPS Lost Time
Cleanup Device Buffer
delbuf
Events
events_gv500
pfa_event: Power off event
pna_event: Power on event
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
Fixed Report
fixed_report_gv500
mode: Working Mode
corner: Corner Report
time_range: Time Range
Geofence #1
geofence1
Geofence #1 configuration
lat: Latitude
lon: Longitude
ival: Check Interval
radius: Radius
report: Report
state_mode: State Mode
trigger_mode: Trigger Mode
Geofence #2
geofence2
Geofence #2 configuration
lat: Latitude
lon: Longitude
radius: Radius
report: Report
GSM Reports
gsm_reports_gv500
mode: GSM Reports Mode
reports: Select reports
Network Setup
network_lte
Configure the parameters for LTE network
lte: LTE Mode
network: Network Mode
OBDII Configuration
obd_config_gv500map
OBDII configuration settings
fuel: Fuel Type
check: OBD Reading
report: OBD Report
debounce: IGF Debounce Time
jes_mask: Journey Summary GTJES
event_mask: Event reports
igf_report: OBD IGF Report
report_mask: OBD Report Composition
displacement: Displacement
Report Composition
report_gv500
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
vin_enable: VIN
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virt_ign_accel_gv500
Accelerometer (motion status) virtual ignition settings
rest_timeout: Rest Duration
motion_timeout: Motion Validity
Virtual Ignition Mode
virt_ign_mode_gv500ma
Virtual ignition working mode
virt_ign: Working Mode
Voltage Virtual Ignition
virt_ign_volt_gv500ma
Voltage virtual ignition settings
smart: Smart Voltage
offset: Voltage Offset
on_voltage: Ignition ON Voltage
on_debounce: Ignition ON Debounce
off_debounce: Ignition ON Debounce
