Queclink GV500VC
The GV500VC is a vehicle tracking device that plugs into a vehicle's OBDII port. Its compact design allows easy installation. Its internal OBD reader can obtain information from the vehicle's on-board computer and relay it over CDMA2000 1xRTT networks. Its built-in GPS receiver has superior sensitivity and fast time to first fix. Its dual band CDMA2000 1xRTT allows the GV500VC's location to be monitored in real time or periodically tracked by a backend server and mobile devices. Its built-in 3-axis accelerometer allows motion detection.
Parameters (682)
Settings (10)
Queclink GV500VC
Flespi parses telemetry data from your Queclink GV500VC into a standardized JSON and lets you send commands to Queclink GV500VC via API.
    "device.type.id": "Queclink GV500VC",
How to send commands to Queclink GV500VC?
Device Parameters
config_gv500
agps: AGPS Mode
antenna: GPS Antenna Mode
led_mode: LEDs Working Mode
odometer: Odometer
pwr_mode: Power Saving Mode
sleep_mode: Sleep Mode
device_name: Device Name
no_ign_mode: No Ignition Mode
gps_lost_time: GPS Lost Time
Events
events_gv500
pfa_event: Power off event
pna_event: Power on event
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
Fixed Report
fixed_report_gv500
mode: Working Mode
corner: Corner Report
time_range: Time Range
CDMA Network Setup
network_cdma
Configure the CDMA network parameters
userid: User ID
Report Composition
report_gv500
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
vin_enable: VIN
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
