This article covers how to manage flespi objects with relation to different subaccounts on the example of
HTTP API
Parent accounts can emulate operation from any of its child accounts by setting a special x-flespi-cid HTTP header in each REST API call. Without such header, the request will operate with instances that belong to the branch of subaccounts for the account with the given authorization token. Consider the following account configuration: master account has two subaccounts, each having separate sets of devices:
If master needs to perform HTTP REST API call that operates with a set of devices that belong to Child 1, there are two ways to do so:
Perform a regular REST API call with Token DEF, that belongs to Child 1
Perform REST API call with master account Token ABC, adding the header: x-flespi-cid: 11, e.g.
curl -X GET --header 'x-flespi-cid: 11' --header 'Authorization: FlespiToken ABC’ 'https://flespi.io/gw/devices/all'
Important note: subaccount ID is the number containing inside it's "id" property, while "
MQTT API
MQTT sessions created under the parent account token can subscribe to messages only generated on a specified flespi account’s namespace by passing the
