You can obtain telematics data from any Jimi IoT (Concox) device in 6 easy steps:
Set up the Concox channel in your flespi.io interface.
Point a Jimi IoT device to your flespi account using the device configurator from Jimi IoT or by sending an SMS command to the device.
Access Jimi IoT device data via API.
2. Set up the Concox channel in flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “concox” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Jimi IoT device to your flespi channel
You can do it with the Jimi IoT device configurator tool or by sending an SMS command to the device. The domain name and port to point to are located in the channel box.
The syntax of the SMS command is as follows:
server,1,<domain>,<port>,0#
While in the Channel dialogue box, click on the "Logs and Messages" tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Jimi IoT device data via API
6. Create a flespi device
What's next?
