Obtain telematics data from Suntech devices via API in 5 easy steps:
Create a free flespi account.
Set up the Suntech channel in your flespi.io interface.
Point a Suntech device to your flespi account using the configurator from Suntech or by sending an SMS command to the device.
Access Suntech device data via API.
- [OPTIONAL] Create a flespi device to access telemetry, apply plugins and analytics, and use long-term message storage.
(a) Go to www.flespi.io and click on LOGIN / REGISTER:
(b) You can choose from a number of third-party service accounts to log-in under or the right-most option @ to register with your name and email address:
2. Set up the Suntech channel in your flespi.io interface:
(a) Click on Telematics Hub (1), then on Channels (2), then on the plus button in the lower right corner of the screen (3).
(b) Channel dialogue box will come up. Enter the name for the channel (any text will suffice) (1), select “Suntech” in the protocol_id drop-down (2), click SAVE + OPEN (3):
(c) Channel dialogue will open. Make a note of the domain name and port that you should point your device to. IMPORTANT: Image below indicates where to find the info and is NOT an actual domain/port for you to use.
3. Point your Suntech device to your flespi account using Suntech’s SyncTrak configurator tool (available by request from Suntech tech support) or by sending an SMS command to the device. Domain name and port to point the device to are shown in the channel box.
SMS command syntax can be found in the "Commands" document, hosted at the Suntech Support website. Commands for certain device models are broken out into specific documents:
- UP Commands PDF: https://suntech.makekb.com/file/57/?f=1
- OBD2 Specific UP commands PDF: https://suntech.makekb.com/file/54/?f=1
Suntech tech contacts vary based on the region where the customer is located:
- USA & EMEA: support@suntechus.com | http://suntechus.com/support
- Latin America: https://soporte.suntechlatam.com.
4. Confirm that the device data is being received and parsed:
(a) While in the channel dialogue box, click on TOOLBOX tab:
(b) Ensure BOTH Logs and Messages views are selected. Inspect log records (1) to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen (2) will confirm that the incoming data is parsed.
In case of any issues, check out our troubleshooting checklist.
5. Access Suntech device data via API:
(a) Click on the REST API Documentation menu item in the lower-left corner:
(b) In the menu on the right under Gateway API click on channels:
(c) Scroll down until you see GET /channels/{1-ch-selector}/messages request. Click on it to reveal additional fields.
(d) Put in your channel ID into the 1-ch-selector field (1) and execute the API call (2).
(e) And here you have it. Suntech device messages in an easy to read JSON format:
6. [OPTIONAL] Create a flespi device. This step takes interaction with your device on a qualitatively new level — get access to device telemetry, easily send configuration commands, configure post-processing using plugins, aggregate messages into intervals, benefit from extended message storage.
Click on Telematics Hub (1), then on Devices (2), then on the plus button (3) in the lower right corner of the screen (3). Pick the proper device type and specify the device ID:
What's next?
Explore a variety of data access options.
Manage device settings and control outputs remotely via a universal web-based configuration tool or directly via API.
Push the data to Amazon AWS IoT, Google IoT Cloud, Microsoft Azure IoT, or your own server.
Calculate trips and stops, mileage, tracks, motor hours, and sensor values based on message data.
Get a better understanding of the flespi potential with a wide range of real-life use cases.
