You can obtain telematics data from any Teltonika device in 6 easy steps:
Set up the Teltonika channel in your flespi.io interface.
Point a Teltonika device to your flespi account using the device configurator from Teltonika or by sending an SMS command to the device.
Access Teltonika device data via API.
2. Set up the Teltonika channel in your flespi.io interface
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “teltonika” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Teltonika device to your flespi channel using the Teltonika configurator tool or by sending an SMS command to the device. The domain name and port to point to are located in the Channel box.
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that as the Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Teltonika device data via API
Click on API Playground menu item:
6. Create a flespi device
What's next?
