Queclink CV200XEU/XNA
Queclink CV200 is a smart 4G dash camera with full-featured telematics. The device features LTE Cat 6 for global coverage, optional AI Feature (DMS / ADAS) to enhance safety, FHD front-facing camera and detachable secondary camera for high flexibility, multiple interfaces including BT4.2+BLE, RS232, I/O, optional OBD power cable for easy installation, 470mAh Li-Pol battery, and more.
Take a look at a special instruction on how to utilize Queclink CV200 video functionality with flespi.
Parameters (683)
Settings (11)
Commands (8)
Flespi parses telemetry data from your Queclink CV200XEU/XNA into a standardized JSON and lets you send commands to Queclink CV200XEU/XNA via API.
    "device.type.id": "Queclink CV200XEU/XNA",
How to send commands to Queclink CV200XEU/XNA?
Configure the backend server information (AT+GTSRI command)
backup_host: Backup Server Host
backup_port: Backup Server Port
sms_ack_enable: SMS ACK Enable
Server for Transferring Files
file_transfering
server: Upload mode
Global Configuration
global_configuration
Configure CV200 global parameters (AT+GTCFG command)
events: Events
led_on: LED On
odometer: Odometer
pwr_mode: Power Saving Mode
agps_mode: AGPS Mode
gsm_report: GSM Report
osi_report: OSI Report
device_name: Device Name
gnss_lost_time: GNSS Lost Time
position_append: Position Append
incoming_control: Incoming Call Control
rto_serial_number: RTO Serial Number
report_composition: Report Composition
Network Setup
network_setup
Configure the GSM/WCDMA/LTE network parameters (AT+GTBSI command)
apn_auth: APN Authentication Method
sim_service: SIM Service
network_mode: Network Mode
manual_netreg: Manual Netreg
Recorder configuration
recorder_config
beep: Recording beep
rec_ch2: Record channel 2
rec_dur: Event recording duration
rec_mode: Record mode
rec_audio: Record audio
rec_event: Event metadata report mask
video_roi: Video recording ROI settings
frame_rate: Frame rate
camera_flip: Camera flip
encoding_mode: Encoding mode
pic_event_mask: Picture generate events
vid_event_mask: Video generate events
pic_upload_mask: Picture upload mask
vid_upload_mask: Video upload mask
camera_mono_mask: Camera mono mask
rec_time_ign_off: Recording time after ignition off
video_quality_ch1: Video quality channel 1
video_quality_ch2: Video quality channel 2
event_channel_mask: Event channel mask
forced_event_audio_mask: Forced event audio mask
video_resolution_ratio_ch1: Video resolution ratio channel 1
Request Log
request_log
Upload device diagnostic logs
time_range: Time Range
Storage Card Information
sci
Storage card (TF/SD) status information. Reports slot count, model name, total/used/free space, file system type, and working status for each card slot.
total_slots: Total Number of Slots
slot_1_left_space: Slot 1 Left Space
slot_1_model_name: Slot 1 Model Name
slot_2_left_space: Slot 2 Left Space
slot_2_model_name: Slot 2 Model Name
slot_1_file_system: Slot 1 File System
slot_1_total_space: Slot 1 Total Space
slot_1_usage_space: Slot 1 Usage Space
slot_2_file_system: Slot 2 File System
slot_2_total_space: Slot 2 Total Space
slot_2_usage_space: Slot 2 Usage Space
slot_1_working_status: Slot 1 Working Status
slot_2_working_status: Slot 2 Working Status
Time Adjustment
time_adjustment
Configure NTP address for time synchronization (AT+GTTMA command)
ntp_address: NTP Address
time_zone
Read local time zone of the device
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
Request tachograph file
request_tachograph_file
Stop videostream
stop_videostream
Stop videostream
