Queclink GL300VC
The water resistant GL300VC is a powerful GPS locator designed for lone worker, vehicle, pet and asset tracking applications. The thumb sized button makes this device ideal for applications requiring rapid notification of emergency alert or regular setting of geo-fences based on current location. Its built-in GPS receiver has superior sensitivity and fast time to first fix. Its CDMA2000 1xRTT allows the GL300VC's location to be monitored in real time or periodically tracked by a backend server and mobile devices. Its built-in 3-axis accelerometer allows motion detection and extends battery life through sophisticated power management algorithms.
Parameters (683)
Settings (6)
Queclink GL300VC
Flespi parses telemetry data from your Queclink GL300VC into a standardized JSON and lets you send commands to Queclink GL300VC via API.
    "device.type.id": "Queclink GL300VC",
How to send commands to Queclink GL300VC?
Fixed Report
fixed_report_gl
mode: Working Mode
corner: Corner Report
end_time: End Time
movement: Movement Detect Mode
start_time: Start Time
check_interval: GPS Check Interval
CDMA Network Setup
network_cdma
Configure the CDMA network parameters
userid: User ID
Non-Movement Behavior
non_movement
Non-Movement detection and behavior
movement: Movement
send_interval: Send Interval
