Queclink GL30MG
Queclink GL30MG is a micro LTE Cat M1/NB2 real-time asset tracker with 2G fallback, designed for the North American market. It features multi-constellation GNSS (GPS, GLONASS, Galileo, BeiDou), Wi‑Fi scan and neighbor cell info for enhanced positioning, BLE 5.2, IP67 waterproof housing, internal antennas, and a 650 mAh rechargeable battery with long standby modes. The device supports TCP/UDP/SMS transmission protocols, motion detection via 3‑axis accelerometer, SOS/function button, geo-fences, low power alarm, and OTA configuration and firmware updates.
Parameters (682)
Settings (9)
Queclink GL30MG
Flespi parses telemetry data from your Queclink GL30MG into a standardized JSON and lets you send commands to Queclink GL30MG via API.
    "device.type.id": "Queclink GL30MG",
How to send commands to Queclink GL30MG?
Configure the backend server information (AT+GTSRI command)
host: Main Server Host
port: Main Server Port
backup_host: Backup Server Host
backup_port: Backup Server Port
sms_gateway: SMS Gateway
manual_netreg: Manual Netreg
sms_ack_enable: SMS ACK Enable
psm_network_hold_time: PSM Network Hold Time
Global Configuration
global_configuration
Configure global parameters of the device (AT+GTCFG command)
mode: Working Mode
start: Start Mode
events: Events
gsm_report: GSM Report
sos_report: SOS Report Location
agps_enable: AGPS Enable
device_name: Device Name
fn_key_mode: Function Key Mode
gnss_enable: GNSS Enable
gnss_timeout: GNSS Timeout
report_items: Report Items
battery_low_percentage: Battery Low Percentage
Movement Detection
movement_detection
Configured movement and non-movement detection (AT+GTNMD command)
movement_duration: Movement Duration
movement_threshold: Movement Threshold
rest_send_interval: Rest Send Interval
non_movement_duration: Non-movement Duration
Network Setup
network_setup
Configure the parameters for LTE/EGPRS networks (AT+GTBSI command)
lte: LTE Mode
edrx: Edrx Periodic
network: Network Mode
apn_auth: APN Authentication Method
backup_apn: Backup APN
backup_password: Backup APN Password
backup_username: Backup APN Username
Reboot the terminal
Request position
request_position
Reset Parameters
reset_params
