Queclink GL320MG
Queclink GL320MG is a real-time LTE asset tracker with global Cat M1/NB2 and 2G fallback, internal 2600 mAh battery, up to 300 hours standby, IPX5 water resistance, and optional magnetic waterproof case. It features GNSS positioning, motion detection, ignition detection, SOS button, and supports external battery kits. Ideal for asset, vehicle, and personal security tracking.
Parameters (683)
Settings (11)
Queclink GL320MG
Flespi parses telemetry data from your Queclink GL320MG into a standardized JSON and lets you send commands to Queclink GL320MG via API.
    "device.type.id": "Queclink GL320MG",
How to send commands to Queclink GL320MG?
Configuration Update
config_update
Update configuration of the device over the air
url: Download URL
enable: Enable Download
retries: Download Retries
interval: Update Interval
Fixed Report
fixed_report
Fixed report configuration
mode: Working Mode
corner: Corner Report
mileage: Mileage
distance: Distance
end_time: End Time
eri_mask: Extended Fixed Report Content
movement: Movement Detect Mode
begin_time: Begin Time
send_interval: Send Interval
check_interval: Check Interval
discard_no_fix: Reporting Without GPS Fix
ignition_send_interval: Ignition Send Interval
ignition_check_interval: Ignition Check Interval
Modem Information
modem_info
Modem versions information
sw_ver: Software Version
Network Setup
network_lte_gprs
Configure the parameters for LTE/GPRS networks
lte: LTE Mode
lte_apn: LTE APN
network: Network Mode
gprs_apn: GPRS APN
lte_password: LTE APN Password
lte_username: LTE APN Username
gprs_password: GPRS APN Password
gprs_username: GPRS APN Username
Reboot the terminal
Request position
request_position
Reset Parameters
reset_params
Safe Flight Manager
safe_flight
Safe flight manager configuration
on_time: GPS On Timeout
altitude: Altitude
g_sensor: GSensor Mode
off_time: GPS Off Timeout
open_gps_interval: Open GPS Interval
