Queclink GL533CG
Queclink GL533CG is a waterproof asset tracker with LTE Cat 1 and 2G fallback. It supports RF433 and BLE for extended connectivity and features a battery life of up to 4 years. The device has IP67 rating, enabling outdoor and indoor use with superior asset visibility. It includes features like jamming detection, tamper detection, GNSS with GPS, Glonass, Galileo, Beidou support, and more in a compact, magnetic case.
Parameters (721)
Settings (28)
Queclink GL533CG
Flespi parses telemetry data from your Queclink GL533CG into a standardized JSON and lets you send commands to Queclink GL533CG via API.
    "device.type.id": "Queclink GL533CG",
How to send commands to Queclink GL533CG?
Data ID 115,
Data ID 116,
antihijack.alarm.status
Report GTACJ
antihijack.event.enum
Anti-hijack event code
Report GTACJ
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
CAN item 56 of Data ID 53,
can.abs.fully.operational
can.abs.indicator.status
CAN item 24 of Data ID 53,
CAN item 34 of Data ID 53,
CAN item 35 of Data ID 53,
CAN item 36 of Data ID 53,
CAN item 37 of Data ID 53,
CAN item 38 of Data ID 53,
CAN item 57 of Data ID 53,
CAN item 55 of Data ID 53
can.brake.fluid.status
Brake fluid status
can.brake.lights.status
CAN item 32 of Data ID 53
CAN item 55 of Data ID 53,
CAN item 51 of Data ID 53,
Data ID 54
can.door.state.enum
CAN item 53 of Data ID 53
CAN item 48 of Data ID 53,
CAN item 21 of Data ID 53,
CAN item 44 of Data ID 53,
CAN item 30 of Data ID 53
CAN item 39 of Data ID 53,
CAN item 9 of Data ID 53,
CAN item 29 of Data ID 53,
CAN item 19 of Data ID 53,
can.engine.start.count
CAN item 45 of Data ID 53
CAN item 22 of Data ID 53,
CAN item 20 of Data ID 53,
CAN item 63 of Data ID 53
CAN item 66 of Data ID 53
CAN item 64 of Data ID 53
CAN item 67 of Data ID 53
CAN item 7 of Data ID 53,
CAN item 25 of Data ID 53,
CAN item 8 of Data ID 53,
CAN item 26 of Data ID 53,
can.fuel.rate
Fuel rate read from CAN
CAN item 23 of Data ID 53
CAN item 28 of Data ID 53,
CAN item 27 of Data ID 53,
CAN item 43 of Data ID 53,
can.j1939.dm1.dtc.pl
CAN item 52 of Data ID 53
CAN item 50 of Data ID 53,
CAN item 33 of Data ID 53,
CAN item 49 of Data ID 53,
can.seatbelt.indicator.status
CAN item 40 of Data ID 53
CAN item 31 of Data ID 53,
CAN item 58 of Data ID 53
CAN item 47 of Data ID 53,
CAN item 15 of Data ID 53,
CAN item 46 of Data ID 53,
CAN item 12 of Data ID 53,
CAN item 11 of Data ID 53,
CAN item 16 of Data ID 53,
CAN item 10 of Data ID 53,
CAN item 14 of Data ID 53,
CAN item 42 of Data ID 53,
CAN item 41 of Data ID 53,
CAN item 13 of Data ID 53,
CAN item 59 of Data ID 53
CAN item 60 of Data ID 53
CAN item 70 of Data ID 53,
CAN item 68 of Data ID 53
CAN item 61 of Data ID 53
CAN item 69 of Data ID 53,
CAN item 62 of Data ID 53,
CAN item 65 of Data ID 53,
CAN item 6 of Data ID 53,
CAN item 17 of Data ID 53
CAN item 18 of Data ID 53,
Report GTTOW
Report GTTOW
Report GTTOW
Report GTALC,
Report GTALL,
Report GTALS,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
passengers.in.count
passengers.out.count
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
CAN item 2 of Data ID 53,
CAN item 3 of Data ID 53,
CAN item 4 of Data ID 53,
CAN item 5 of Data ID 53,
Report GTPDP,
Report GTPLA,
Report GTALC,
Report GTALL,
Report GTALS,
CAN item 1 of Data ID 53,
CAN item 0 of Data ID 53,
Configure APN settings
username: Username
Request Position Report
ping
Power Off
power_off
Power OFF the terminal
Default Profile (0)
qrc_default
data_ids: Data IDs
record_count: Record Count
time_interval: Time Interval
qrc_device_info
data_ids: Data IDs
Emergency Profile (63)
qrc_emergency
data_ids: Data IDs
Ignition Off Profile (7)
qrc_ignition_off
Fixed Report Configuration for Ignition Off Profile (Profile 7) Active when vehicle ignition is off. Reduces reporting to save power.
data_ids: Data IDs
Ignition On Profile (6)
qrc_ignition_on
Fixed Report Configuration for Ignition On Profile (Profile 6) Active when vehicle ignition is turned on.
data_ids: Data IDs
Low Battery Profile (10)
qrc_low_battery
data_ids: Data IDs
Low Power Profile (11)
qrc_low_power
Fixed Report Configuration for Low Power Profile (Profile 11) Active when external power supply is low. Reduces activity to extend runtime.
data_ids: Data IDs
Motion Profile (4)
qrc_motion
Fixed Report Configuration for Motion Profile (Profile 4) Active when motion/vibration is detected.
data_ids: Data IDs
Motionless Profile (5)
qrc_motionless
Fixed Report Configuration for Motionless Profile (5) Active when device is stationary.
data_ids: Data IDs
Off Duty Profile (3)
qrc_off_duty
Fixed Report Configuration for Off Duty Profile (Profile 3) Active during off-duty hours. Hides real location for privacy.
data_ids: Data IDs
Roaming Profile (1)
qrc_roaming
Fixed Report Configuration for Roaming Profile (Profile 1) Active when device is in a roaming network area.
data_ids: Data IDs
Wi-Fi Environment Profile (9)
qrc_wifi
Fixed Report Configuration for Wi-Fi Environment Profile (Profile 9) Active when device is under known Wi-Fi hotspot coverage.
data_ids: Data IDs
Reboot the terminal
Backend Server 0
server_0
stay_time: Stay Time
Backend Server 1
server_1
Tire Pressure Alarm 0
tpm_0
type: Type
sensor_id: Sensor ID
alarm_mode: Alarm Mode
Tire Pressure Alarm 1
tpm_1
type: Type
Tire Pressure Alarm 2
tpm_2
type: Type
Tire Pressure Alarm 3
tpm_3
type: Type
Tire Pressure Alarm 4
tpm_4
type: Type
Tire Pressure Alarm 5
tpm_5
type: Type
Tire Pressure Alarm 6
tpm_6
type: Type
Tire Pressure Alarm 7
tpm_7
type: Type
Tire Pressure Alarm 8
tpm_8
type: Type
Tire Pressure Alarm 9
tpm_9
type: Type
