Queclink GV300CAN
Queclink GV300CAN is a compact GNSS tracker with CAN ports for various vehicle tracking applications. The device features CAN and J1708 ports, 3-axis accelerometer, multiple I/O ports, 1-Wire interface, virtual odometer support, and more.
Parameters (723)
Settings (24)
Commands (3)
Queclink GV300CAN
Flespi parses telemetry data from your Queclink GV300CAN into a standardized JSON and lets you send commands to Queclink GV300CAN via API.
    "device.type.id": "Queclink GV300CAN",
How to send commands to Queclink GV300CAN?
Data ID 115,
Data ID 116,
antihijack.alarm.status
Report GTACJ
antihijack.event.enum
Anti-hijack event code
Report GTACJ
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
CAN item 56 of Data ID 53,
can.abs.fully.operational
can.abs.indicator.status
CAN item 24 of Data ID 53,
CAN item 34 of Data ID 53,
CAN item 35 of Data ID 53,
CAN item 36 of Data ID 53,
CAN item 37 of Data ID 53,
CAN item 38 of Data ID 53,
CAN item 57 of Data ID 53,
CAN item 55 of Data ID 53
can.brake.fluid.status
Brake fluid status
can.brake.lights.status
CAN item 32 of Data ID 53
CAN item 55 of Data ID 53,
CAN item 51 of Data ID 53,
Data ID 54
can.door.state.enum
CAN item 53 of Data ID 53
CAN item 48 of Data ID 53,
CAN item 21 of Data ID 53,
CAN item 44 of Data ID 53,
CAN item 30 of Data ID 53
CAN item 39 of Data ID 53,
CAN item 9 of Data ID 53,
CAN item 29 of Data ID 53,
CAN item 19 of Data ID 53,
can.engine.start.count
CAN item 45 of Data ID 53
CAN item 22 of Data ID 53,
CAN item 20 of Data ID 53,
CAN item 63 of Data ID 53
CAN item 66 of Data ID 53
CAN item 64 of Data ID 53
CAN item 67 of Data ID 53
CAN item 7 of Data ID 53,
CAN item 25 of Data ID 53,
CAN item 8 of Data ID 53,
CAN item 26 of Data ID 53,
can.fuel.rate
Fuel rate read from CAN
CAN item 23 of Data ID 53
CAN item 28 of Data ID 53,
CAN item 27 of Data ID 53,
CAN item 43 of Data ID 53,
can.j1939.dm1.dtc.pl
CAN item 52 of Data ID 53
CAN item 50 of Data ID 53,
CAN item 33 of Data ID 53,
CAN item 49 of Data ID 53,
can.seatbelt.indicator.status
CAN item 40 of Data ID 53
CAN item 31 of Data ID 53,
CAN item 58 of Data ID 53
CAN item 47 of Data ID 53,
CAN item 15 of Data ID 53,
CAN item 46 of Data ID 53,
CAN item 12 of Data ID 53,
CAN item 11 of Data ID 53,
CAN item 16 of Data ID 53,
CAN item 10 of Data ID 53,
CAN item 14 of Data ID 53,
CAN item 42 of Data ID 53,
CAN item 41 of Data ID 53,
CAN item 13 of Data ID 53,
CAN item 59 of Data ID 53
CAN item 60 of Data ID 53
CAN item 70 of Data ID 53,
CAN item 68 of Data ID 53
CAN item 61 of Data ID 53
CAN item 69 of Data ID 53,
CAN item 62 of Data ID 53,
CAN item 65 of Data ID 53,
CAN item 6 of Data ID 53,
CAN item 17 of Data ID 53
CAN item 18 of Data ID 53,
Report GTTOW
Report GTTOW
Report GTTOW
Report GTALC,
Report GTALL,
Report GTALS,
Report GTEPJ,
Report GTEPJ,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTEPJ,
external.powersource.voltage.previous
External power voltage before the voltage jump
Report GTEPJ
gps.module.version
GPS module version
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
passengers.in.count
passengers.out.count
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTEPJ,
CAN item 2 of Data ID 53,
CAN item 3 of Data ID 53,
CAN item 4 of Data ID 53,
CAN item 5 of Data ID 53,
Report GTPDP,
Report GTPLA,
Report GTALC,
Report GTALL,
Report GTALS,
Report GTEPJ,
CAN item 1 of Data ID 53,
Report GTEPJ,
CAN item 0 of Data ID 53,
Analog Input
analog_input
Analog Input Port Configuration
fuel: Fuel Analog Input
input1: Analog Input #1
input2: Analog Input #2
change_threshold: Change Threshold
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
DR100 Card Reader
cda
DR100 RFID card reader configuration. Configures read mode, card key, memory block, and prefix strings for card validation.
key: Key
read_mode: Read Mode
data_block: Data Block
prefix_number: Prefix Number
prefix_string_1: Prefix String 1
prefix_string_2: Prefix String 2
prefix_string_3: Prefix String 3
prefix_string_4: Prefix String 4
prefix_string_5: Prefix String 5
prefix_string_6: Prefix String 6
prefix_string_7: Prefix String 7
prefix_string_8: Prefix String 8
prefix_string_9: Prefix String 9
prefix_string_10: Prefix String 10
Device Parameters
config
agps: AGPS Mode enable
led_mode: LEDs working mode
odometer: Odometer
pwr_mode: Power saving mode
pin15_mode: Pin 15 mode
device_name: Device Name
gps_on_need: GPS On Need
gps_lost_time: GPS lost time
Events
events
ant_event: External GPS antenna status changed
pfa_event: Power off event
pna_event: Power on event
ufs_event: UFSxxx fault code
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
Fixed Report
fixed_report_gv
mode: Working Mode
corner: Corner Report
time_range: Time Range
GSM Reports
gsm_reports
mode: GSM Reports Mode
reports: Select reports
Digital Inputs
inputs3
Digital Inputs Control
input1: Input #1
input2: Input #2
ignition: Ignition Input
network_gsm
network_mode: Network Mode
Reboot the terminal
Report Composition
report
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Request position
request_position
Reset Parameters
reset_params
Data Transmission
send_data
Transparent transmission of data to equipment connected to the serial port of the device
ack: Command ACK
crlf: Send data without CRLF
data: Data
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
UART Serial Port
uart_serial_port_gv
Configure the serial port
mode: Working Mode
sleep: Sleep Enable
baudrate: Baudrate
data_bits: Data Bits
stop_bits: Stop Bits
parity_bits: Parity Bits
wakeup_input: Enable Wakeup Input
Request tachograph file
request_tachograph_file
