Queclink GV30CEU
GV30CEU is a compact LTE Cat 1 GNSS vehicle tracker with 2G fallback for EMEA. It features covert, IP54-ready design, internal GNSS/cellular/BLE antennas, wide 9-90V power with 200 mAh backup battery, and BLE 5.4 gateway for beacons and sensors. Multi-constellation GPS/BeiDou/Galileo/GLONASS delivers <2 m accuracy. Functions include geofencing, scheduled reporting, motion and tow alarms, ignition and virtual ignition detection, jamming detection, driving behavior monitoring, crash detection and accident reconstruction, SOS via panic button, remote output control, buffered storage, and OTA configuration via micro USB.
Parameters (682)
Settings (12)
Queclink GV30CEU
Flespi parses telemetry data from your Queclink GV30CEU into a standardized JSON and lets you send commands to Queclink GV30CEU via API.
    "device.type.id": "Queclink GV30CEU",
How to send commands to Queclink GV30CEU?
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
network_gsm
network_mode: Network Mode
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
time_zone2
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
