Queclink GV310LAU
Queclink GV310LAU is an advanced LTE vehicle GPS tracker. The device features LTE Cat 4 | 3G | 2G connectivity, multiple interfaces (RS232 as well as digital and analog I/O), support for various accessories (CAN reader, temperature and humidity sensors), support diversity antenna, BLE 5.2, 250 mAh battery, and more.
Parameters (683)
Settings (19)
Queclink GV310LAU
Flespi parses telemetry data from your Queclink GV310LAU into a standardized JSON and lets you send commands to Queclink GV310LAU via API.
    "device.type.id": "Queclink GV310LAU",
How to send commands to Queclink GV310LAU?
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
CAN100 Information
can_info
CAN100 module information
serial: Serial Number
sw_ver: Software Version
DR100 Card Reader
cda
DR100 RFID card reader configuration. Configures read mode, card key, memory block, and prefix strings for card validation.
key: Key
read_mode: Read Mode
data_block: Data Block
prefix_number: Prefix Number
prefix_string_1: Prefix String 1
prefix_string_2: Prefix String 2
prefix_string_3: Prefix String 3
prefix_string_4: Prefix String 4
prefix_string_5: Prefix String 5
prefix_string_6: Prefix String 6
prefix_string_7: Prefix String 7
prefix_string_8: Prefix String 8
prefix_string_9: Prefix String 9
prefix_string_10: Prefix String 10
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
Fixed Report
fixed_report_gv
mode: Working Mode
corner: Corner Report
time_range: Time Range
Digital Inputs
inputs
Digital Inputs Control
input1: Input #1
input2: Input #2
input3: Input #3
ignition: Ignition Input
network_gsm
network_mode: Network Mode
Reboot the terminal
Request position
request_position
Reset Parameters
reset_params
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
time_zone2
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
