Queclink GV350M
Queclink GV350 (LTE) is a GNSS tracker for a variety of fleet management applications. The device features two RS232 serial ports, 1-wire interface, GARMIN FMI/Multiple Sensors, 3-axis accelerometer, Bluetooth Low Energy 4.0 support, driving behavior monitoring, and incident notification. The tracker supports LTE CAT-M1 (eMTC) / LTE CAT-M2 (NB-IoT) suitable for both North America and Europe.
Parameters (723)
Settings (23)
Queclink GV350M
Flespi parses telemetry data from your Queclink GV350M into a standardized JSON and lets you send commands to Queclink GV350M via API.
    "device.type.id": "Queclink GV350M",
How to send commands to Queclink GV350M?
Data ID 115,
Data ID 116,
antihijack.alarm.status
Report GTACJ
antihijack.event.enum
Anti-hijack event code
Report GTACJ
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
CAN item 56 of Data ID 53,
can.abs.fully.operational
can.abs.indicator.status
CAN item 24 of Data ID 53,
CAN item 34 of Data ID 53,
CAN item 35 of Data ID 53,
CAN item 36 of Data ID 53,
CAN item 37 of Data ID 53,
CAN item 38 of Data ID 53,
CAN item 57 of Data ID 53,
CAN item 55 of Data ID 53
can.brake.fluid.status
Brake fluid status
can.brake.lights.status
CAN item 32 of Data ID 53
CAN item 55 of Data ID 53,
CAN item 51 of Data ID 53,
Data ID 54
can.door.state.enum
CAN item 53 of Data ID 53
CAN item 48 of Data ID 53,
CAN item 21 of Data ID 53,
CAN item 44 of Data ID 53,
CAN item 30 of Data ID 53
CAN item 39 of Data ID 53,
CAN item 9 of Data ID 53,
CAN item 29 of Data ID 53,
CAN item 19 of Data ID 53,
can.engine.start.count
CAN item 45 of Data ID 53
CAN item 22 of Data ID 53,
CAN item 20 of Data ID 53,
CAN item 63 of Data ID 53
CAN item 66 of Data ID 53
CAN item 64 of Data ID 53
CAN item 67 of Data ID 53
CAN item 7 of Data ID 53,
CAN item 25 of Data ID 53,
CAN item 8 of Data ID 53,
CAN item 26 of Data ID 53,
can.fuel.rate
Fuel rate read from CAN
CAN item 23 of Data ID 53
CAN item 28 of Data ID 53,
CAN item 27 of Data ID 53,
CAN item 43 of Data ID 53,
can.j1939.dm1.dtc.pl
CAN item 52 of Data ID 53
CAN item 50 of Data ID 53,
CAN item 33 of Data ID 53,
CAN item 49 of Data ID 53,
can.seatbelt.indicator.status
CAN item 40 of Data ID 53
CAN item 31 of Data ID 53,
CAN item 58 of Data ID 53
CAN item 47 of Data ID 53,
CAN item 15 of Data ID 53,
CAN item 46 of Data ID 53,
CAN item 12 of Data ID 53,
CAN item 11 of Data ID 53,
CAN item 16 of Data ID 53,
CAN item 10 of Data ID 53,
CAN item 14 of Data ID 53,
CAN item 42 of Data ID 53,
CAN item 41 of Data ID 53,
CAN item 13 of Data ID 53,
CAN item 59 of Data ID 53
CAN item 60 of Data ID 53
CAN item 70 of Data ID 53,
CAN item 68 of Data ID 53
CAN item 61 of Data ID 53
CAN item 69 of Data ID 53,
CAN item 62 of Data ID 53,
CAN item 65 of Data ID 53,
CAN item 6 of Data ID 53,
CAN item 17 of Data ID 53
CAN item 18 of Data ID 53,
Report GTTOW
Report GTTOW
Report GTTOW
Report GTALC,
Report GTALL,
Report GTALS,
Report GTEPJ,
Report GTEPJ,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTEPJ,
external.powersource.voltage.previous
External power voltage before the voltage jump
Report GTEPJ
gps.module.version
GPS module version
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
passengers.in.count
passengers.out.count
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEPJ,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTEPJ,
CAN item 2 of Data ID 53,
CAN item 3 of Data ID 53,
CAN item 4 of Data ID 53,
CAN item 5 of Data ID 53,
Report GTPDP,
Report GTPLA,
Report GTALC,
Report GTALL,
Report GTALS,
Report GTEPJ,
CAN item 1 of Data ID 53,
Report GTEPJ,
CAN item 0 of Data ID 53,
Configuration Update
config_update
Update configuration of the device over the air
url: Download URL
enable: Enable Download
retries: Download Retries
interval: Update Interval
Cleanup Device Buffer
delbuf
Fixed Report
fixed_report_gv
mode: Working Mode
corner: Corner Report
time_range: Time Range
Events
gtcfg_events_gv350m
Configure events that will cause reporting a message to the backend server
ant_event: External GPS antenna status changed
exp_event: Report fuel sensor malfunction
pfa_event: Power off event
pna_event: Power on event
pnl_event: Power on location report
GSM Reports
gtcfg_gsm_report_gv350m
Control how or when to report cells’ information
mode: GSM Reports Mode
reports: Select reports
Global Configuration
gtcfg_gv350
Configure global parameters of the device
agps: AGPS Mode Enable
debounce: Sensor Debounce
led_mode: LEDs Mode
odometer: Odometer
pwr_mode: Power Saving Mode
work_time: Work Time
pin15_mode: Pin 15 Mode
charge_mode: Charge Mode
device_name: Device Name
wakeup_ival: Wake Up Interval
onewire_ival: 1-Wire Sample Interval
gps_lost_time: GPS Lost Time
Report Composition
gtcfg_report_mask_gv350m
Configure the composition of report message and GPS information
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Crash Alarm
gtcra_gv350m
Crash alarm settings
mode: Enable
output: Output
gnss_pre: GNSS Data Pre-Crash
gnss_post: GNSS Data Post-Crash
sensitivity: Sensitivity
sample_period_pre: Sample Period Pre-Crash
sample_period_post: Sample Period Post-Crash
GNSS Jamming Alarm
gtgpj_gv350m
GNSS jamming alarm settings
mode: Enable
output: Output
bb_threshold: Broadband Threshold
nb_threshold: Narrowband Threshold
Driving Behavior Alarm
gthbm_gv350
Driving behavior alarm settings
ha: High Acceleration Threshold
hb: High Braking Threshold
la: Low Acceleration Threshold
lb: Low Braking Threshold
ma: Medium Acceleration Threshold
mb: Medium Braking Threshold
mode: Working Mode
output: Output
a_duration: Acceleration Duration
b_duration: Braking Duration
speed_high: High Speed
a_threshold: Acceleration Threshold
b_threshold: Braking Threshold
speed_medium: Medium Speed
Speed Alarm
gtspd_gv350m
Speed alarm settings
output: Output
max_spd: Max Speed
min_spd: Min Speed
send_ival: Send Interval
Network Setup
network_lte_gprs
Configure the parameters for LTE/GPRS networks
lte: LTE Mode
lte_apn: LTE APN
network: Network Mode
gprs_apn: GPRS APN
lte_password: LTE APN Password
lte_username: LTE APN Username
gprs_password: GPRS APN Password
gprs_username: GPRS APN Username
output1_gv350m
Digital Output 1
gtdos: GTDOS Report
limit: Long Operation
output2_gv350m
Digital Output 2
wave: Wave Shape
Output 3
output3_gv350m
Digital Output 3
wave: Wave Shape
Request Position Report
ping
Power Off
power_off
Power OFF the terminal
Reboot the terminal
Reset Parameters
reset_params
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
