Queclink GV500CNA
The GV500CNA is a compact LTE Cat 1 OBD tracker designed for vehicle telematics. It offers driver behavior monitoring, crash detection, mileage recording, and BLE 5.1 connectivity. The device is ideal for insurance applications and connected car services, with features like GNSS, virtual ignition detection, geo-fences, and remote control DSP. It supports both nano SIM and eSIM, has internal antennas, and operates in a wide temperature range, making it versatile for various automotive applications.
Parameters (683)
Settings (28)
Queclink GV500CNA
Flespi parses telemetry data from your Queclink GV500CNA into a standardized JSON and lets you send commands to Queclink GV500CNA via API.
    "device.type.id": "Queclink GV500CNA",
How to send commands to Queclink GV500CNA?
Configure APN settings
username: Username
Request Position Report
ping
Power Off
power_off
Power OFF the terminal
Default Profile (0)
qrc_default
data_ids: Data IDs
record_count: Record Count
time_interval: Time Interval
qrc_device_info
data_ids: Data IDs
Emergency Profile (63)
qrc_emergency
data_ids: Data IDs
Ignition Off Profile (7)
qrc_ignition_off
Fixed Report Configuration for Ignition Off Profile (Profile 7) Active when vehicle ignition is off. Reduces reporting to save power.
data_ids: Data IDs
Ignition On Profile (6)
qrc_ignition_on
Fixed Report Configuration for Ignition On Profile (Profile 6) Active when vehicle ignition is turned on.
data_ids: Data IDs
Low Battery Profile (10)
qrc_low_battery
data_ids: Data IDs
Low Power Profile (11)
qrc_low_power
Fixed Report Configuration for Low Power Profile (Profile 11) Active when external power supply is low. Reduces activity to extend runtime.
data_ids: Data IDs
Motion Profile (4)
qrc_motion
Fixed Report Configuration for Motion Profile (Profile 4) Active when motion/vibration is detected.
data_ids: Data IDs
Motionless Profile (5)
qrc_motionless
Fixed Report Configuration for Motionless Profile (5) Active when device is stationary.
data_ids: Data IDs
Off Duty Profile (3)
qrc_off_duty
Fixed Report Configuration for Off Duty Profile (Profile 3) Active during off-duty hours. Hides real location for privacy.
data_ids: Data IDs
Roaming Profile (1)
qrc_roaming
Fixed Report Configuration for Roaming Profile (Profile 1) Active when device is in a roaming network area.
data_ids: Data IDs
Wi-Fi Environment Profile (9)
qrc_wifi
Fixed Report Configuration for Wi-Fi Environment Profile (Profile 9) Active when device is under known Wi-Fi hotspot coverage.
data_ids: Data IDs
Reboot the terminal
Backend Server 0
server_0
stay_time: Stay Time
Backend Server 1
server_1
Tire Pressure Alarm 0
tpm_0
type: Type
sensor_id: Sensor ID
alarm_mode: Alarm Mode
Tire Pressure Alarm 1
tpm_1
type: Type
Tire Pressure Alarm 2
tpm_2
type: Type
Tire Pressure Alarm 3
tpm_3
type: Type
Tire Pressure Alarm 4
tpm_4
type: Type
Tire Pressure Alarm 5
tpm_5
type: Type
Tire Pressure Alarm 6
tpm_6
type: Type
Tire Pressure Alarm 7
tpm_7
type: Type
Tire Pressure Alarm 8
tpm_8
type: Type
Tire Pressure Alarm 9
tpm_9
type: Type
