Queclink GV500MA
Queclink GV500MA is an LTE Cat M1/NB1 easy-to-install OBDII GPS tracker. The device features driving behavior monitoring, motion detection, accident data collection for reconstruction and analysis, low power alarm, tow alarm, geo-fence alarm, parking alarm, 60 mAh backup battery, and more.
Parameters (721)
Settings (20)
Queclink GV500MA
Flespi parses telemetry data from your Queclink GV500MA into a standardized JSON and lets you send commands to Queclink GV500MA via API.
    "device.type.id": "Queclink GV500MA",
How to send commands to Queclink GV500MA?
Data ID 115,
Data ID 116,
antihijack.alarm.status
Report GTACJ
antihijack.event.enum
Anti-hijack event code
Report GTACJ
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
CAN item 56 of Data ID 53,
can.abs.fully.operational
can.abs.indicator.status
CAN item 24 of Data ID 53,
CAN item 34 of Data ID 53,
CAN item 35 of Data ID 53,
CAN item 36 of Data ID 53,
CAN item 37 of Data ID 53,
CAN item 38 of Data ID 53,
CAN item 57 of Data ID 53,
CAN item 55 of Data ID 53
can.brake.fluid.status
Brake fluid status
can.brake.lights.status
CAN item 32 of Data ID 53
CAN item 55 of Data ID 53,
CAN item 51 of Data ID 53,
Data ID 54
can.door.state.enum
CAN item 53 of Data ID 53
CAN item 48 of Data ID 53,
CAN item 21 of Data ID 53,
CAN item 44 of Data ID 53,
CAN item 30 of Data ID 53
CAN item 39 of Data ID 53,
CAN item 9 of Data ID 53,
CAN item 29 of Data ID 53,
CAN item 19 of Data ID 53,
can.engine.start.count
CAN item 45 of Data ID 53
CAN item 22 of Data ID 53,
CAN item 20 of Data ID 53,
CAN item 63 of Data ID 53
CAN item 66 of Data ID 53
CAN item 64 of Data ID 53
CAN item 67 of Data ID 53
CAN item 7 of Data ID 53,
CAN item 25 of Data ID 53,
CAN item 8 of Data ID 53,
CAN item 26 of Data ID 53,
can.fuel.rate
Fuel rate read from CAN
CAN item 23 of Data ID 53
CAN item 28 of Data ID 53,
CAN item 27 of Data ID 53,
CAN item 43 of Data ID 53,
can.j1939.dm1.dtc.pl
CAN item 52 of Data ID 53
CAN item 50 of Data ID 53,
CAN item 33 of Data ID 53,
CAN item 49 of Data ID 53,
can.seatbelt.indicator.status
CAN item 40 of Data ID 53
CAN item 31 of Data ID 53,
CAN item 58 of Data ID 53
CAN item 47 of Data ID 53,
CAN item 15 of Data ID 53,
CAN item 46 of Data ID 53,
CAN item 12 of Data ID 53,
CAN item 11 of Data ID 53,
CAN item 16 of Data ID 53,
CAN item 10 of Data ID 53,
CAN item 14 of Data ID 53,
CAN item 42 of Data ID 53,
CAN item 41 of Data ID 53,
CAN item 13 of Data ID 53,
CAN item 59 of Data ID 53
CAN item 60 of Data ID 53
CAN item 70 of Data ID 53,
CAN item 68 of Data ID 53
CAN item 61 of Data ID 53
CAN item 69 of Data ID 53,
CAN item 62 of Data ID 53,
CAN item 65 of Data ID 53,
CAN item 6 of Data ID 53,
CAN item 17 of Data ID 53
CAN item 18 of Data ID 53,
Report GTTOW
Report GTTOW
Report GTTOW
Report GTALC,
Report GTALL,
Report GTALS,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
passengers.in.count
passengers.out.count
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
CAN item 2 of Data ID 53,
CAN item 3 of Data ID 53,
CAN item 4 of Data ID 53,
CAN item 5 of Data ID 53,
Report GTPDP,
Report GTPLA,
Report GTALC,
Report GTALL,
Report GTALS,
CAN item 1 of Data ID 53,
CAN item 0 of Data ID 53,
Device Parameters
config_gv500
agps: AGPS Mode
antenna: GPS Antenna Mode
led_mode: LEDs Working Mode
odometer: Odometer
pwr_mode: Power Saving Mode
sleep_mode: Sleep Mode
device_name: Device Name
no_ign_mode: No Ignition Mode
gps_lost_time: GPS Lost Time
Cleanup Device Buffer
delbuf
Events
events_gv500
pfa_event: Power off event
pna_event: Power on event
External Power Supply Alarm
ext_power_alarm_without_output
sync: Sync With FRI
debounce: Debounce Time
Fixed Report
fixed_report_gv500
mode: Working Mode
corner: Corner Report
time_range: Time Range
Geofence #1
geofence1
Geofence #1 configuration
lat: Latitude
lon: Longitude
ival: Check Interval
radius: Radius
report: Report
state_mode: State Mode
trigger_mode: Trigger Mode
Geofence #2
geofence2
Geofence #2 configuration
lat: Latitude
lon: Longitude
radius: Radius
report: Report
GSM Reports
gsm_reports_gv500
mode: GSM Reports Mode
reports: Select reports
Network Setup
network_lte
Configure the parameters for LTE network
lte: LTE Mode
network: Network Mode
Reboot the terminal
Report Composition
report_gv500
alt_enable: Altitude
gsm_enable: GSM tower data
mil_enable: Mileage
vin_enable: VIN
dname_enable: Device name
speed_enable: Speed
stime_enable: Send time
course_enable: Course
Request position
request_position
Reset Parameters
reset_params
Tow Alarm
tow_alarm_without_output
Tow alarm configuration
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virt_ign_accel_gv500
Accelerometer (motion status) virtual ignition settings
rest_timeout: Rest Duration
motion_timeout: Motion Validity
Virtual Ignition Mode
virt_ign_mode_gv500ma
Virtual ignition working mode
virt_ign: Working Mode
Voltage Virtual Ignition
virt_ign_volt_gv500ma
Voltage virtual ignition settings
smart: Smart Voltage
offset: Voltage Offset
on_voltage: Ignition ON Voltage
on_debounce: Ignition ON Debounce
off_debounce: Ignition ON Debounce
