Queclink GV53MG
Queclink GV53MG is a compact vehicle LTE Cat M1/NB2 GPS tracker for a wide range of vehicle tracking applications. The device features a 190 mAh Li-Pol battery, 1 digital input, 1 digital output, 1 configurable I/O, geofencing, driving behavior monitoring, towing alarm, crash detection, and more.
Parameters (682)
Settings (13)
Queclink GV53MG
Flespi parses telemetry data from your Queclink GV53MG into a standardized JSON and lets you send commands to Queclink GV53MG via API.
    "device.type.id": "Queclink GV53MG",
How to send commands to Queclink GV53MG?
backup_host: Backup Server Host
backup_port: Backup Server Port
sms_gateway: SMS Gateway
sms_ack_enable: SMS ACK
encryption_mode: Encryption Mode
protocol_format: Protocol Format
Jamming Detection
gtjdc
Jamming detection configuration
output_id: Output ID
quit_timer: Quit Jamming Timer
enter_timer: Enter Jamming Timer
toggle_times: Toggle Times
output_status: Output Status
lte_threshold1: LTE Threshold 1
lte_threshold2: LTE Threshold 2
threshold_2g_1: 2G Threshold 1
threshold_2g_2: 2G Threshold 2
Power Conservation
gtpcs
PPP connection power conservation settings
enable: Enable PPP Deactivation
time_to_deactivate: Time to Deactivate
Modem Information
modem_info
Modem versions information
sw_ver: Software Version
Network Setup
network_setup
Configure the parameters for LTE/EGPRS networks (AT+GTBSI command)
lte: LTE Mode
network: Network Mode
apn_auth: APN Authentication Method
backup_apn: Backup APN
manual_netreg: Manual Netreg
backup_password: Backup APN Password
backup_username: Backup APN Username
Digital Output 1
gtdos: GTDOS Report
limit: Long Operation
ign_on: Ignition On restrict output
Digital Output 2
wave: Wave Shape
Reboot with delay
reboot_delay
delay: Delay
Request position with timeout
request_position_timeout
Request the device to report current position with specified timeout. If the GNSS chip fails to get a position within this time, it will be shut down and the device will send the last known location.
timeout: GNSS Fix timeout
time_zone2
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
Virtual Ignition Mode
virt_ign_mode
Virtual ignition working mode
mode: Working Mode
