Queclink GV57MGP
The GV57MG Plus is an IoT device for vehicle and motorcycle tracking, with waterproof IP67 casing and advanced power management for zero battery drain when the vehicle's ignition is off. It supports LTE Cat M1/NB2, Bluetooth 5.1, and a range of reporting features such as geo-fencing, speed, tow, and SOS alarms. Equipped with a long-lasting 1400mAh battery, it ensures reliable performance in harsh environments and a variety of applications including theft recovery.
Parameters (683)
Settings (10)
Queclink GV57MGP
Flespi parses telemetry data from your Queclink GV57MGP into a standardized JSON and lets you send commands to Queclink GV57MGP via API.
    "device.type.id": "Queclink GV57MGP",
How to send commands to Queclink GV57MGP?
Digital Input
inputs2
Digital Inputs Control
input1: Input #1
ignition: Ignition Input
Digital Output
output
Digital output configuration and manipulation
gtdos: GTDOS Report
limit: Long Operation
ign_on: Ignition On restrict output
output: Enable
Request Position Report
ping
Power Off
power_off
Power OFF the terminal
Reboot the terminal
Reset Parameters
reset_params
time_zone2
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
