Queclink GV58CEU
Queclink GV58CEU is a cost-effective compact LTE GPS tracker. The device features LTE Cat 1 connectivity, BLE 5.2, 190 mAh Li-Pol battery, 1-wire interface, and more.
Parameters (721)
Settings (23)
Queclink GV58CEU
Flespi parses telemetry data from your Queclink GV58CEU into a standardized JSON and lets you send commands to Queclink GV58CEU via API.
    "device.type.id": "Queclink GV58CEU",
How to send commands to Queclink GV58CEU?
Data ID 115,
Data ID 116,
antihijack.alarm.status
Report GTACJ
antihijack.event.enum
Anti-hijack event code
Report GTACJ
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTMPL,
Report GTPCE,
Report GTSCE,
CAN item 56 of Data ID 53,
can.abs.fully.operational
can.abs.indicator.status
CAN item 24 of Data ID 53,
CAN item 34 of Data ID 53,
CAN item 35 of Data ID 53,
CAN item 36 of Data ID 53,
CAN item 37 of Data ID 53,
CAN item 38 of Data ID 53,
CAN item 57 of Data ID 53,
CAN item 55 of Data ID 53
can.brake.fluid.status
Brake fluid status
can.brake.lights.status
CAN item 32 of Data ID 53
CAN item 55 of Data ID 53,
CAN item 51 of Data ID 53,
Data ID 54
can.door.state.enum
CAN item 53 of Data ID 53
CAN item 48 of Data ID 53,
CAN item 21 of Data ID 53,
CAN item 44 of Data ID 53,
CAN item 30 of Data ID 53
CAN item 39 of Data ID 53,
CAN item 9 of Data ID 53,
CAN item 29 of Data ID 53,
CAN item 19 of Data ID 53,
can.engine.start.count
CAN item 45 of Data ID 53
CAN item 22 of Data ID 53,
CAN item 20 of Data ID 53,
CAN item 63 of Data ID 53
CAN item 66 of Data ID 53
CAN item 64 of Data ID 53
CAN item 67 of Data ID 53
CAN item 7 of Data ID 53,
CAN item 25 of Data ID 53,
CAN item 8 of Data ID 53,
CAN item 26 of Data ID 53,
can.fuel.rate
Fuel rate read from CAN
CAN item 23 of Data ID 53
CAN item 28 of Data ID 53,
CAN item 27 of Data ID 53,
CAN item 43 of Data ID 53,
can.j1939.dm1.dtc.pl
CAN item 52 of Data ID 53
CAN item 50 of Data ID 53,
CAN item 33 of Data ID 53,
CAN item 49 of Data ID 53,
can.seatbelt.indicator.status
CAN item 40 of Data ID 53
CAN item 31 of Data ID 53,
CAN item 58 of Data ID 53
CAN item 47 of Data ID 53,
CAN item 15 of Data ID 53,
CAN item 46 of Data ID 53,
CAN item 12 of Data ID 53,
CAN item 11 of Data ID 53,
CAN item 16 of Data ID 53,
CAN item 10 of Data ID 53,
CAN item 14 of Data ID 53,
CAN item 42 of Data ID 53,
CAN item 41 of Data ID 53,
CAN item 13 of Data ID 53,
CAN item 59 of Data ID 53
CAN item 60 of Data ID 53
CAN item 70 of Data ID 53,
CAN item 68 of Data ID 53
CAN item 61 of Data ID 53
CAN item 69 of Data ID 53,
CAN item 62 of Data ID 53,
CAN item 65 of Data ID 53,
CAN item 6 of Data ID 53,
CAN item 17 of Data ID 53
CAN item 18 of Data ID 53,
Report GTTOW
Report GTTOW
Report GTTOW
Report GTALC,
Report GTALL,
Report GTALS,
Report GTMPL,
Report GTPCE,
Report GTSCE,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
passengers.in.count
passengers.out.count
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
Report GTACJ,
Report GTBND,
Report GTEST,
Report GTFMS,
Report GTOER,
Report GTPBA,
Report GTPFC,
Report GTSOA,
Report GTTRI,
CAN item 2 of Data ID 53,
CAN item 3 of Data ID 53,
CAN item 4 of Data ID 53,
CAN item 5 of Data ID 53,
Report GTPDP,
Report GTPLA,
Report GTALC,
Report GTALL,
Report GTALS,
CAN item 1 of Data ID 53,
CAN item 0 of Data ID 53,
CAN Data Setup
can_gv
mode: Enable CAN Report
expansion: CAN Extended Report
CAN100 Information
can_info
CAN100 module information
serial: Serial Number
sw_ver: Software Version
External Power Supply Alarm
ext_power_alarm
sync: Sync With FRI
output: Output
debounce: Debounce Time
Fixed Report
fixed_report_gb
mode: Working Mode
corner: Corner Report
time_range: Time Range
check_interval: Check interval
Geofence #1
geofence1
Geofence #1 configuration
lat: Latitude
lon: Longitude
ival: Check Interval
radius: Radius
report: Report
state_mode: State Mode
trigger_mode: Trigger Mode
Geofence #2
geofence2
Geofence #2 configuration
lat: Latitude
lon: Longitude
radius: Radius
report: Report
GNSS Assisted Motion
gnss_motion_detection_gb100
GNSS assisted motion detection settings
speed: Speed Mode
enable: Enable Function
move_time: Motion Time
speed_lvl: Speed Threshold
still_time: Motionless Time
gnss_fail_time: GNSS Fix Failure Timeout
Crash Alarm
gtcra_gv58ceu
Crash alarm settings
toggles: Output Toggle Times
duration: Output Toggle Period
output_id: Output ID
threshold_x: Threshold X
threshold_y: Threshold Y
threshold_z: Threshold Z
output_status: Output Status
samples_after: Samples After Crash
samples_before: Samples Before Crash
sampling_start: Sampling Start
Speed Alarm
gtspd_gv58ceu
Speed alarm settings
output: Output
max_spd: Max Speed
min_spd: Min Speed
send_ival: Send Interval
Harsh Behavior Monitoring
harsh_behavior_monitoring
Configure driving behavior detection and reports (AT+GTHBM). Motion-sensor thresholds use the device's raw values.
high_speed: High Speed
low_braking: Low Speed Braking Threshold
high_braking: High Speed Braking Threshold
medium_speed: Medium Speed
brake_duration: Brake Duration
medium_braking: Medium Speed Braking Threshold
output_toggles: Output Toggle Times
brake_threshold: Brake Threshold
discard_unknown: Discard Unknown Event
output_duration: Output Toggle Period
low_acceleration: Low Speed Acceleration Threshold
behavior_duration: Behavior Duration
high_acceleration: High Speed Acceleration Threshold
cornering_duration: Cornering and Braking Duration
cornering_threshold: Cornering and Braking Threshold
medium_acceleration: Medium Speed Acceleration Threshold
acceleration_duration: Acceleration Duration
acceleration_threshold: Acceleration Threshold
network_gsm
network_mode: Network Mode
Temperature Alarm 0
temperature_alarm0
alarm: Mode
Temperature Alarm 1
temperature_alarm1
alarm: Mode
Temperature Alarm 2
temperature_alarm2
alarm: Mode
Temperature Alarm 3
temperature_alarm3
alarm: Mode
time_zone2
dst: Daylight Saving
sign: Sign
hours_offset: Hour Offset
minutes_offset: Minute Offset
Tow Alarm
tow_alarm
Tow alarm settings
output: Output
rest_dur: Stillness Timeout
motion_dur: Motion Timeout
tow_enable: Tow Alarm
tow_interval: Tow Interval
virt_ign_accel_gv500
Accelerometer (motion status) virtual ignition settings
rest_timeout: Rest Duration
motion_timeout: Motion Validity
Virtual Ignition Mode
virt_ign_mode_gv500ma
Virtual ignition working mode
virt_ign: Working Mode
Voltage Virtual Ignition
virt_ign_volt_gv500ma
Voltage virtual ignition settings
smart: Smart Voltage
offset: Voltage Offset
on_voltage: Ignition ON Voltage
on_debounce: Ignition ON Debounce
off_debounce: Ignition ON Debounce
