Queclink GV58CG
The GV58CG is a cost-effective LTE Cat 1 GNSS tracker designed for fleet management applications, including car rental, leasing, and logistics. It features support for BLE 5.2, enabling driver identification over 1-wire or BLE, and offers a range of BLE-based sensors. With internal antennas, low-power alerts, ignition detection, fuel cutoff, and driver behavior monitoring, the device efficiently reports positions using TCP/UDP/SMS protocols. Its compact design allows for discreet installation and it operates across various LTE and GNSS bands, with a backup battery and wide operating temperature range.
Parameters (683)
Settings (28)
Queclink GV58CG
Flespi parses telemetry data from your Queclink GV58CG into a standardized JSON and lets you send commands to Queclink GV58CG via API.
    "device.type.id": "Queclink GV58CG",
How to send commands to Queclink GV58CG?
Configure APN settings
username: Username
Request Position Report
ping
Power Off
power_off
Power OFF the terminal
Default Profile (0)
qrc_default
data_ids: Data IDs
record_count: Record Count
time_interval: Time Interval
qrc_device_info
data_ids: Data IDs
Emergency Profile (63)
qrc_emergency
data_ids: Data IDs
Ignition Off Profile (7)
qrc_ignition_off
Fixed Report Configuration for Ignition Off Profile (Profile 7) Active when vehicle ignition is off. Reduces reporting to save power.
data_ids: Data IDs
Ignition On Profile (6)
qrc_ignition_on
Fixed Report Configuration for Ignition On Profile (Profile 6) Active when vehicle ignition is turned on.
data_ids: Data IDs
Low Battery Profile (10)
qrc_low_battery
data_ids: Data IDs
Low Power Profile (11)
qrc_low_power
Fixed Report Configuration for Low Power Profile (Profile 11) Active when external power supply is low. Reduces activity to extend runtime.
data_ids: Data IDs
Motion Profile (4)
qrc_motion
Fixed Report Configuration for Motion Profile (Profile 4) Active when motion/vibration is detected.
data_ids: Data IDs
Motionless Profile (5)
qrc_motionless
Fixed Report Configuration for Motionless Profile (5) Active when device is stationary.
data_ids: Data IDs
Off Duty Profile (3)
qrc_off_duty
Fixed Report Configuration for Off Duty Profile (Profile 3) Active during off-duty hours. Hides real location for privacy.
data_ids: Data IDs
Roaming Profile (1)
qrc_roaming
Fixed Report Configuration for Roaming Profile (Profile 1) Active when device is in a roaming network area.
data_ids: Data IDs
Wi-Fi Environment Profile (9)
qrc_wifi
Fixed Report Configuration for Wi-Fi Environment Profile (Profile 9) Active when device is under known Wi-Fi hotspot coverage.
data_ids: Data IDs
Reboot the terminal
Backend Server 0
server_0
stay_time: Stay Time
Backend Server 1
server_1
Tire Pressure Alarm 0
tpm_0
type: Type
sensor_id: Sensor ID
alarm_mode: Alarm Mode
Tire Pressure Alarm 1
tpm_1
type: Type
Tire Pressure Alarm 2
tpm_2
type: Type
Tire Pressure Alarm 3
tpm_3
type: Type
Tire Pressure Alarm 4
tpm_4
type: Type
Tire Pressure Alarm 5
tpm_5
type: Type
Tire Pressure Alarm 6
tpm_6
type: Type
Tire Pressure Alarm 7
tpm_7
type: Type
Tire Pressure Alarm 8
tpm_8
type: Type
Tire Pressure Alarm 9
tpm_9
type: Type
