You can obtain telematics data from any Topflytech device in 6 easy steps:
Set up the Topflytech channel in your flespi.io interface.
Point a Topflytech device to your flespi account using the device configurator from Topflytech or by sending an SMS command to the device.
Access Topflytech device data via API.
2. Set up the Topflytech channel on flespi.io
The Channel dialogue box will show up. Enter the name for the channel (any text will suffice), select “topflytech” in the protocol_id drop-down menu, click 'SAVE + OPEN'.
3. Point your Topflytech device to your flespi channel
Yo can do it with TopFlyTech’s configuration tool or by sending an SMS command to the device. The domain name and port to point to are located in the Channel box.
The syntax of the SMS command is as follows:
IP,password,domain,port#
By default, the device will communicate over TCP. If you need to switch to UDP mode, you need to send this follow-up command:
DMODE,password,2#
While in the Channel dialogue box, click on the Logs & Messages tab. Inspect log records to confirm that your device has successfully connected to flespi. The presence of messages in the lower half of the screen will confirm that the incoming data is parsed. Please keep in mind that in as Logs section runs in realtime it will reflect any connection attempt. Hint: you can right-click on a message or log to show corresponding raw traffic.
5. Access Topflytech device data via API
"result": [
"ain.1": 0,
"ain.2": 0,
"battery.level": 100,
"channel.id": 11766,
"device.id": 2222385,
"device.name": "Ford Mustang",
"device.type.id": 973,
"din": 0,
"din.1": false,
"din.2": false,
"din.3": false,
"din.4": false,
"engine.blocked.status": false,
"engine.ignition.status": false,
"external.powersource.status": true,
"external.powersource.voltage": 12.83,
"gnss.status": false,
"gsm.signal.level": 32,
"ident": "86772321121226848",
"message.buffered.status": false,
"message.type": "gnss",
"peer": "45.154.16.5:18587",
"position.altitude": 1100.541992,
"position.direction": 97,
"position.latitude": 51.060116,
"position.longitude": -113.991974,
"position.satellites": 16,
"position.speed": 0,
"position.valid": true,
"protocol.id": 120,
"report.reason": 2,
"server.timestamp": 1705027947.276748,
"timestamp": 1705027946,
"vehicle.mileage": 20248.981
}6. Create a flespi device
This step takes interaction with your device on a qualitatively new level — get access to device telemetry, easily send configuration commands, configure post-processing using plugins, aggregate messages into intervals, and benefit from extended message storage.
What's next?
